メインコンテンツにスキップ
Samsung Galaxy Tab Pro 8.4 Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 2、 2の画像 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 4、 1の画像 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 5、 1の画像 1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 手順 6、 3の画像 1 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 手順 6、 3の画像 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 手順 6、 3の画像 3
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 7、 3の画像 1 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 7、 3の画像 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 7、 3の画像 3
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 手順 8、 3の画像 3
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
ゴール
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
victor johnson
メンバー登録日: 10/05/16
242 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016人のメンバー
USFT-LACY-F16S9G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 2,356
