はじめに
This guide will show you how to replace the battery on the Samsung Galaxy Tab Pro 10.1. First, the process will involve removing the rear panel of the device which will allow access to the interior where the battery is located. Then, the steps to remove the battery for replacement will be outlined.
必要な工具と部品
Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
Go around the entire crevice with the plastic opening tool.
Set aside the separated front and rear panels of the device.
Remove the tape that runs along the length of the battery.
Lift the retaining flaps of the ZIF connectors on each side of the battery connector.
Remove the two ribbon cables that lie across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
この手順で使用する道具:Tweezers$4.99
Using tweezers, remove the top center 6 pin power connector that is attached to the edge of the motherboard from the center of the battery. To unplug it, pull it upwards away from the motherboard.
Detach the battery by gently lifting the battery out of the panel.
Das Abziehen/Abheben des Steckers von der Hauptplatine muss mit äußerster Vorsicht geschehen. Im letzten Moment vor dem Lösen macht er gerne einen Ruck, wobei der Steckerteil auf der Platine bei mir brach und sich die Lötkontakte lösten.
21 の人々がこのガイドを完成させました。
8 件のコメント
My Samsung Galaxy Tab Pro sm-t520 screen pooped up from the base where the plugin for charging, only partly, and the screen is pretty much bowed up what can I do and the home button is very loose just happened by itself heard a pop like plastic sound and then looked and now Where home button is screen bowed up slightly how can that happen, I use the charger etc that came with my tablet and what would it cost to fix around figure possibly can a battery go bad even when I have not charged it in a long time, have not even been playing on it for several weeks. Please help ty
Oh it was a loud snap sound.
Well can't open it cause have not the right tools.
I would invest in a Opening Tools
like the one from ifixit so you can open the tablet. You need to see how it looks inside to know if you can repair and how.
Claes -
Very well written guide with picture guidance. Well done and thank you!
Well written.
But after replacing the battery I have a problem. I wanted to charge the new one to fully 100% but I could not exceed 93%.
After discharge and charge I've charged up to 80%. But I misured voltage on cell. is 4,2V. it looks like the battery is fully charged but the tablet can not read it well. I need some calibrations battery or something else? Android is not rooted. I have original Kitkat 4.4.
