メインコンテンツにスキップ
Samsung Galaxy Tab E Lite 7 Kids Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: 手順 1、 3の画像 1 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: 手順 1、 3の画像 2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: 手順 1、 3の画像 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 2、 2の画像 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: 手順 3、 3の画像 1 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: 手順 3、 3の画像 2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: 手順 3、 3の画像 3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 4、 2の画像 2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 5、 2の画像 2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 6、 1の画像 1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 7、 1の画像 1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 8、 3の画像 3
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
  9. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Camera: 手順 9、 2の画像 1 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Camera: 手順 9、 2の画像 2
    • Flip the motherboard over.
    • Use a plastic opening tool to lift up the latch holding the camera cable.
  10. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 10、 3の画像 1 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 10、 3の画像 2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 手順 10、 3の画像 3
    • Pull the ribbon cable and the camera.
終わりに
作成者
3人の作成者と共同で作成されました。
Jordan Bermudez
メンバー登録日: 02/17/17
285 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S19-G2, Hoffman Spring 2017 USF Tampa, Team S19-G2, Hoffman Spring 2017人のメンバー
USFT-HOFFMAN-S17S19G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 318
