メインコンテンツにスキップ
Samsung Galaxy Tab E 9.6 Wi-Fi Battery Replacement
必要な工具と部品
ビデオの概要
  1. Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement, Back Panel: 手順 1、 3の画像 1 Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement, Back Panel: 手順 1、 3の画像 2 Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement, Back Panel: 手順 1、 3の画像 3
    • Be sure to shut power to the tablet off and remove any external power source before beginning this step.
    • Insert one of the blue plastic opening tools between the glass display and the edge of the tablet's outer shell to break the seal around the display. It doesn't matter where you start the process, but once you form a gap, continue opening the gap around the edge of the device.
    • The display assembly and back casing should gently come apart after a gap is formed around the perimeter.
    • This step requires quite a bit of force to open the tablet. Don't be shy about it. Once you do make a gap, be careful not to pinch your fingers!
  2. Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement, Battery: 手順 2、 1の画像 1
    • Attached to the back side of the display you will find the all of the primary computer hardware including the battery. You will need to remove six 3-millimeter Phillips head PH000 screws and two ribbon cables.
    • Do not puncture or damage the battery casing seen in white.
  3. Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement: 手順 3、 3の画像 3
    • The first ribbon cable to remove is the longer of the two. It overlaps the entire battery. It is marked in orange in the Step 2 image.
    • Using the precision tweezers gently remove the green tape over the clip at the end of the ribbon cable.
    • Last, gently lift the clip lever and the ribbon cable should should easily slide out from its slot.
  4. Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement: 手順 4、 1の画像 1
    • The second ribbon cable to remove is the wider, orange ribbon. The process is very similar to step 2. This ribbon is seen marked up in yellow in the image in step 2.
  5. Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement: 手順 5、 1の画像 1
    • Using the "PH000 driver" to remove the 6 three-millimeter screws around the battery casing. All 6 screws are circled in red in the image seen in step 2.
  6. Samsung Galaxy Tab E 9.6 Wi-Fi Battery  Replacement: 手順 6、 1の画像 1
    • Once all the 6 screws and 2 ribbons are removed, the battery should come free of the display assembly very easily.
    • With one hand on each side of the tablet simply turn the device on edge with one hand and tilt it over until the battery falls into your other hand.
    • If for some reason the battery does not come out, double check to ensure you have removed and unattached all of the 6 screws and 2 ribbon cables.
終わりに
30 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Eric Williams
メンバー登録日: 06/27/16
899 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 1-2, Rowley SU 2016 Eastern Washington University, Team 1-2, Rowley SU 2016人のメンバー
EWU-ROWLEY-SU16S1G2
3 メンバー
6のガイドは作成済み
10 件のコメント
thanks. busted the screen in 2 seconds flat!
retourula - 返信
Here are some tips to pry the cover off without damaging the digitizer: the cover is cemented with adhesive tape, making it hard to insert a tool into the seam, so heat the edge only first. Once you have it warm (not hot), use all of your fingers on the power button side to pull the plastic edge, using your thumbs to press on the back - do not try to pry or press against the glass side. Also, do not slide the pry tool under the glass and lift up, you can crack the glass. It takes patience
seadawg - 返信
"Warm, not hot," is roughly between 175 - 200 degrees Fahrenheit. (80 to 100 Celsius).
B. A. Computer Services -
First step is not easy. Do what seadawg did above. Dont bother with plastic tools. Start near the power button. Dont try to go between the screen and tablet. Pull back the plastic instead. I wish I had read seadawgs advice first, would have saved me a digitiser and a load of time…
Gavin Minion - 返信
Where do u even get the tools? also how is this supposed to work if everyones saying it will crack the screen?
mrs khule - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 46
過去 30 日: 171
今までの合計 47,423
