メインコンテンツにスキップ
はじめに
Front panel removal for the Samsung Galaxy Tab E Verizon.
パーツ
パーツは指定されていません。
  1. If the device has a micro-SD or SIM card inserted, remove them from the device before continuing.
    • If the device has a micro-SD or SIM card inserted, remove them from the device before continuing.
    • Verify your device is turned OFF after removing all external peripherals from it. Power down the device if it's turned on.
  2. Insert a plastic opening tool in between the edge of the device's screen and its back cover. Once the tool is wedged between the glass and back casing, move the tool around the edges of the device to undo the plastic clips holding the casing attached. Inserting the tool and prying off the back casing requires a good deal of force. If you're having trouble undoing the clips, try using a suction cup on the screen to increase separation with the back casing. Inserting the tool and prying off the back casing requires a good deal of force. If you're having trouble undoing the clips, try using a suction cup on the screen to increase separation with the back casing.
    • Insert a plastic opening tool in between the edge of the device's screen and its back cover. Once the tool is wedged between the glass and back casing, move the tool around the edges of the device to undo the plastic clips holding the casing attached.
    • Inserting the tool and prying off the back casing requires a good deal of force. If you're having trouble undoing the clips, try using a suction cup on the screen to increase separation with the back casing.
  3. As more clips are undone, it will become easier to further separate the device from its casing. Once you're able to separate roughly half of the device from the back casing, use your hands to gently pull the back cover off of the device. Don't forget: after creating some separation between the device and back case, you can use a suction cup attached to the screen to aid in pulling the device apart. Don't forget: after creating some separation between the device and back case, you can use a suction cup attached to the screen to aid in pulling the device apart.
    • As more clips are undone, it will become easier to further separate the device from its casing. Once you're able to separate roughly half of the device from the back casing, use your hands to gently pull the back cover off of the device.
    • Don't forget: after creating some separation between the device and back case, you can use a suction cup attached to the screen to aid in pulling the device apart.
  4. Turn the device over so the screen is facing down. Locate the front panel assembly connector at the top left corner of the motherboard. To remove the connector, first use a pair of tweezers and flip the connector lock upwards towards the battery.
    • Turn the device over so the screen is facing down. Locate the front panel assembly connector at the top left corner of the motherboard.
    • To remove the connector, first use a pair of tweezers and flip the connector lock upwards towards the battery.
  5. Once you've undone the connector lock, use a pair of tweezers to pull the cable front its housing.
    • Once you've undone the connector lock, use a pair of tweezers to pull the cable front its housing.
  6. Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
    • Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
    • You will need to wedge a plastic opening tool in between the front casing and the screen. Then move the tool around the perimeter of the device to break the adhesive.
    • Once you've loosed the front panel enough with the prying tool, you can use your hands to pull the front panel off of the device.
終わりに
6 の人々がこのガイドを完成させました。
Dave Dorzback
メンバー登録日: 2016年09月28日
566 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S1G4
3 メンバー
14のガイドは作成済み
コメント1件
To install the new screen, install the connector at the top first and dry fit before installing and make sure you align the Button and Camera.
Oscar C - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 3,993
