はじめに
The screen of the Samsung Galaxy Tab E 8.0 may become damaged if the device is dropped or struck by a hard object. This guide shows how to replace the tablet's screen, which is attached to the front panel.
必要な工具と部品
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device.
Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
You will need to use an iOpener or apply heat to separate the digitizer, especially if the glass is shattered. The bottom near the home button and the entire top portion has thick strips of black adhesive.
6 の人々がこのガイドを完成させました。
deffently got to apply heat to that front screen due to the adessive bewhind or mostlikly crack the screen
Trent Weaver - 返信
