はじめに
The motherboard of the Samsung Galaxy Tab E 8.0 may malfunction after overuse of the device. This guide will show how to replace the tablet's motherboard, which is attached to the front panel.
必要な工具と部品
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Use the tweezers to lift the switch connecting the back camera to the motherboard.
Use your hand to remove the back camera from the motherboard.
Use the tweezers to lift the switch connecting the front camera to the motherboard.
Remove the front camera from the motherboard by lifting with the tweezers.
Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
Release the strap from the switch by lifting the strap with your hand.
ある他の人がこのガイドを完成しました。
