Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Make sure the device is off and the SD card is removed before taking off the back casing.
Use the tweezers to flip the switch of the connector.
Lift the connector from the motherboard.
This connector does not come completely off, but disconnects from the motherboard.
Use the tweezers to flip the switch of the blue connector on the motherboard.
This switch can detach from the device, but just needs to disconnect from the motherboard.
Ensure the blue ribbon cable is not under the motherboard upon reassembly.
Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
