この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The audio jack for the Samsung Galaxy Tab E 8.0 may not work due to internal damages or overuse. This guide shows how to replace the tablet's audio jack, which is connected to the motherboard.
必要な工具と部品
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Use the tweezers to lift the switch connecting the back camera to the motherboard.
Use your hand to remove the back camera from the motherboard.
Use the tweezers to lift the switch connecting the front camera to the motherboard.
Remove the front camera from the motherboard by lifting with the tweezers.
Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
Release the strap from the switch by lifting the strap with your hand.
ある他の人がこのガイドを完成しました。
