メインコンテンツにスキップ
Samsung Galaxy Tab A Digitizer Replacement
必要な工具と部品
  1. Samsung Galaxy Tab A Digitizer Replacement, Digitizer: 手順 1、 1の画像 1
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
  2. Samsung Galaxy Tab A Digitizer Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab A Digitizer Replacement: 手順 2、 2の画像 2
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Samsung Galaxy Tab A Digitizer Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab A Digitizer Replacement: 手順 3、 2の画像 2
    • Use the spudger to disconnect the touchscreen from the motherboard. The two are connected at the top half of the motherboard where the yellow rubber portion of the touchscreen is located.
    • The first and second pictures illustrate the touchscreen when it connected and disconnected, respectively.
  4. Samsung Galaxy Tab A Digitizer Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab A Digitizer Replacement: 手順 4、 2の画像 2
    • Use the spudger to separate the touch screen from the front cover of the device.
    • The touch screen is glued onto the front cover, so this step in the process requires patience and a fair amount of strength.
    • The top and bottom portions of the touch screen are more reinforced with glue than the other sections, so extra force will be required.
    • It is recommended to push inwards from the sides using the spudger to separate the top and bottom section from the front cover.
  5. Samsung Galaxy Tab A Digitizer Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab A Digitizer Replacement: 手順 5、 2の画像 2
    • Once the touchscreen is loose enough, slowly pull it off the front cover to fully remove it from the rest of the device.
    • Avoid pulling the touchscreen off too quickly as this could result in damaging or even breaking the touchscreen. This could result in damaging the touchscreen connector in the back of the device.
    • The picture shows what the device should look like once the touchscreen is fully removed.
終わりに
39 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Michael Wozny
メンバー登録日: 02/04/16
3,693 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 17-4, Blackwell Winter 2016 USF Tampa, Team 17-4, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S17G4
4 メンバー
11のガイドは作成済み
13 件のコメント
These steps worked well but you must use a metal spudger to get this started. I didn't have one and it was a nightmare. I finished the project but it was very difficult to start. I would also use a heat gun to loosen the glue for the bottom and top. Just my opinion from my experience.
lasthager - 返信
See comments on the last step re: avoiding the area of the flex connector, and using heat, as the previous commenter suggested, throughout the removal process to loosen the adhesive and avoid breaking the glass.
Also, the “metal" frame around the digitizer is very susceptible to being dented. Be very careful of it.
Finally, a piece of advice from other iFixit commenters about cleaning the LCD before adding new glass: careful circular motions with a very clean, dry microfiber cloth are sufficient in most cases. If not, a small amount of water can be added to the cloth. Avoid adding alcohol or water directly to the LCD, as it is easily smudged.
Bonnie Baxter - 返信
^This! An iOpener or heat is a MUST when separating the digitizer and LCD. There is no way the digitizer just pops off. This is especially important if the digitizer is cracked and spider-webbed.
Jeana Morales -
Oops--one final suggestion, also from other iFixit commenters (I can't find the original, or I’d reference it. It's in the Q&A section, answering a question about jumpy digitizer responses after screen replacement.)
The first time I did this, all seemed well until I tried to use the digitizer, when its response to touch was suddenly very jumpy and erratic in all areas of the screen. The next time I followed Ifixit advice and covered all metallic-looking areas of the back of the new screen with thin Kapton tape, and had no problems. I essentially made a thin frame of Kapton all the way around the non-transparent areas of the screen.
There have been various suggestions about why this might work, most speculating on small electrical shorts occurring between these metallic areas and the metal parts of the frame surrounding the LCD. I just know that it's quick and easy and seems to work.
Bonnie Baxter - 返信
Hi Bonnie, would you happen to know what thickness of tape that should be? I’m getting little to no response then when I put the back on i’m getting nothing at all.
freeaswind -
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 125
今までの合計 32,838
