メインコンテンツにスキップ
Samsung Galaxy Tab A 9.7 Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Tab A 9.7 Motherboard Replacement, Back Cover: 手順 1、 1の画像 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Motherboard Replacement, Battery: 手順 2、 2の画像 1 Samsung Galaxy Tab A 9.7 Motherboard Replacement, Battery: 手順 2、 2の画像 2
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 3、 2の画像 2
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 4、 2の画像 2
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 5、 2の画像 2
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
  6. Samsung Galaxy Tab A 9.7 Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 Samsung Galaxy Tab A 9.7 Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Use a #000 Philips screwdriver to remove the three 2.8mm screws attaching the motherboard to the device.
  7. Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 7、 2の画像 1 Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 7、 2の画像 2
    • Use a plastic opening tool to pry the two connectors near the charging port from the motherboard.
  8. Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    購入する
    • The digitizer is connected to the motherboard near the top of the device. It must be disconnected to remove the motherboard.
    • With your fingers, peel back the plastic sticker placed over the connector.
    • Using metal tweezers, gently flip the now-exposed black portion of the connector up.
    • Gently pull the copper-covered portion of the connector away from the motherboard.
  9. Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 9、 3の画像 1 Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 9、 3の画像 2 Samsung Galaxy Tab A 9.7 Motherboard Replacement: 手順 9、 3の画像 3
    • Using your fingers or a spudger, gently remove the motherboard from the device.
    • Keep in mind that both the front and back facing cameras are connected to the motherboard, so be careful when removing them.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Paulina Nguyen
メンバー登録日: 04/26/17
982 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S1-G3, Livingston Spring 2017 Cal Poly, Team S1-G3, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S1G3
1 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 19
今までの合計 3,374
