メインコンテンツにスキップ
Samsung Galaxy Tab A 9.7 Display Replacement
必要な工具と部品
  1. Samsung Galaxy Tab A 9.7 Display Replacement, Back Cover: 手順 1、 1の画像 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Display Replacement, Battery: 手順 2、 2の画像 1 Samsung Galaxy Tab A 9.7 Display Replacement, Battery: 手順 2、 2の画像 2
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7 Display Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab A 9.7 Display Replacement: 手順 3、 2の画像 2
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7 Display Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab A 9.7 Display Replacement: 手順 4、 2の画像 2
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7 Display Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab A 9.7 Display Replacement: 手順 5、 2の画像 2
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
  6. Samsung Galaxy Tab A 9.7 Display Replacement, Display: 手順 6、 1の画像 1
    • Gently remove the tape covering the screen ribbon cable, located at the top of the devise.
    • With the plastic spudger, disconnect the ribbon cable from the motherboard, located at the middle of the device.
  7. Samsung Galaxy Tab A 9.7 Display Replacement: 手順 7、 1の画像 1
    • Using a plastic spudger, work around the edge of the screen, prying the screen away from the device.
  8. Samsung Galaxy Tab A 9.7 Display Replacement: 手順 8、 1の画像 1
    • Use the left side of the tablet as a hinge to swing the display assembly open.
    • As you move the display assembly, make sure that the display ribbon cable is unattached.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jakob Gerald Schumacher
メンバー登録日: 02/20/20
298 ポイント
3のガイドは作成済み
コメント 1 件
my device burnt down.
HetBesteNaam - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 42
今までの合計 2,621
