メインコンテンツにスキップ
Samsung Galaxy Tab A 9.7 Charging Port Replacement
必要な工具と部品
  1. Samsung Galaxy Tab A 9.7 Charging Port Replacement, Back Cover: 手順 1、 1の画像 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Charging Port Replacement, Speakers: 手順 2、 2の画像 1 Samsung Galaxy Tab A 9.7 Charging Port Replacement, Speakers: 手順 2、 2の画像 2
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Charging Port Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    Heavy-Duty Spudger
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
  4. Samsung Galaxy Tab A 9.7 Charging Port Replacement, Charging Port: 手順 4、 3の画像 1 Samsung Galaxy Tab A 9.7 Charging Port Replacement, Charging Port: 手順 4、 3の画像 2 Samsung Galaxy Tab A 9.7 Charging Port Replacement, Charging Port: 手順 4、 3の画像 3
    • Remove the four 2.8mm #000 Phillips screws that hold the charging port and headphone jack in place.
  5. Samsung Galaxy Tab A 9.7 Charging Port Replacement: 手順 5、 1の画像 1
    • Disconnect the green square connector from the motherboard. To do so, put the flat end of the plastic opening tool underneath the connector and push down.
    • During reassembly, two clicks signify the charging board is completely attached to the motherboard.
  6. Samsung Galaxy Tab A 9.7 Charging Port Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    Heavy-Duty Spudger
    • Place the heavy duty spudger underneath the charging port and push down to remove the charging port.
    • To reinsert the charging port, angle the port downwards towards the battery. Then press down the outside edge of the charging port.
  7. Samsung Galaxy Tab A 9.7 Charging Port Replacement: 手順 7、 1の画像 1
    • Peel the charging assembly from the device to completely remove the charging port from the device.
終わりに
18 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Paulina Nguyen
メンバー登録日: 04/26/17
982 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S1-G3, Livingston Spring 2017 Cal Poly, Team S1-G3, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S1G3
1 メンバー
12のガイドは作成済み
9 件のコメント
Note that you have to transfer the shroud over the charge port from the old assembly to the new one, if the replacement part wasn’t supplied with it. This threw me when I was screwing the new unit in, until I inspected the old part more closely. Also, it takes a lot more effort than you would expect to undo the case in the first place!
Lee Cooke - 返信
How did you glue it on to the new board? Which glue did you use
swordart -
Taking the cover off wasn’t the easiest, but after that it went really smooth. Thanks for the instructions! It really helped a lot! Got my tablet charging again, so I am satisfied!
Brandon Congdon - 返信
there was a tape glued to right part of charging assembly and also part under the right speaker. is it a conductive tape, should it be replaced ? because once peeled off old assembly part, its difficult to put it back on the new one..
Anthony Ménagé - 返信
Are the instructions the same for the SM-P550?
R T - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 37
過去 30 日: 138
今までの合計 27,459
