はじめに
This replacement guide will help you easily follow the steps in order to replace the home button on a Samsung Galaxy Tab A 9.7. If the home button it broken or unresponsive the button should be replaced. The difficulty of this guide is moderate and requires special attention to details.
Ensure to take precautions and store properly when removing small screws.
必要な工具と部品
Insert a metal spudger between the back case and the screen of the device.
Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
Remove the four 2.8mm #000 Phillips screws that hold the charging port and headphone jack in place.
Using a plastic spudger, work around the edge of the screen, prying the screen away from the devise.
Once the the cover is removed, set it aside.
