メインコンテンツにスキップ
Samsung Galaxy Tab A 7.0 Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Tab A 7.0 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0 Battery Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab A 7.0 Battery Replacement: 手順 2、 2の画像 2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0 Battery Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab A 7.0 Battery Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab A 7.0 Battery Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using tweezers, gently lift the black tab locking the wire connecting the battery to the motherboard.
    • Pull wire from connector.
    • This is the only connection for the battery to the motherboard.
  4. Samsung Galaxy Tab A 7.0 Battery Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab A 7.0 Battery Replacement: 手順 4、 2の画像 2
    • Remove the battery from the device.
    • Separating tool may be needed in order to lift battery from device.
終わりに
14 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Bradley Watson
メンバー登録日: 02/15/17
1,079 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 5-4, Passmore Spring 2017 USF Tampa, Team 5-4, Passmore Spring 2017人のメンバー
USFT-PASSMORE-S17S5G4
3 メンバー
8のガイドは作成済み
4 件のコメント
I found there was a layer of double-sided tape backing the battery, and I had to use a flathead screwdriver to get enough force to lever it up. This does not significantly change the guide.
brunius - 返信
It would be nice if you showed which side to remove.
Bob White - 返信
The OEM battery in my device expanded and pushed the screen from the housing. I had to temporarily separate the screen from the housing while leaving the connectors in their sockets while I pried the front housing from the back to reveal the battery. Once the front and back of the chassis were separated, I reattached the screen to the front housing and continued with the procedure. A heat gun made the process much easier by loosening the tape between the screen and housing, but was not necessary to lift the battery or separate the front from the back of the chassis.
Dan Murphy - 返信
Bought a new battery, replaced as said, but seems like new battery is dead. How does one boost it? If I plug into charge, it almost seems like te sceen "flashes" but doesnt come on or show charge bar. Please help.
anciska.mills - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 77
過去 30 日: 436
今までの合計 19,065
