Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
Remember to remove the micro SD card (if present) before you begin.
Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
Lift the back panel off of the device.
The back panel will make a clicking noise while being lifted off of the device.
Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
Lodge the plastic opening tool under and lift the motherboard out of the tablet.
Be careful not to snag any connectors.
Remove the metal bracket that was underneath the charging port and set aside.
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
