メインコンテンツにスキップ
Samsung Galaxy Tab 8.9 Headphone Jack Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Insert Opening tool: 手順 1、 1の画像 1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Insert second tool: 手順 2、 1の画像 1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 3、 1の画像 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 4、 1の画像 1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Battery: 手順 5、 1の画像 1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  6. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 6、 1の画像 1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  7. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 7、 1の画像 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  8. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 8、 1の画像 1
    • Use your hands to open the back cover.
  9. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove Green Tape: 手順 9、 3の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove Green Tape: 手順 9、 3の画像 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove Green Tape: 手順 9、 3の画像 3
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  10. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 10、 2の画像 2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  11. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 11、 3の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 11、 3の画像 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 11、 3の画像 3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  12. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Disconnect Battery from MotherBoard: 手順 12、 3の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Disconnect Battery from MotherBoard: 手順 12、 3の画像 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Disconnect Battery from MotherBoard: 手順 12、 3の画像 3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  13. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 13、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  14. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove the Battery: 手順 14、 3の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove the Battery: 手順 14、 3の画像 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove the Battery: 手順 14、 3の画像 3
    • Use a spudger to lift up and separate the battery from its housing.
  15. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Motherboard: 手順 15、 3の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Motherboard: 手順 15、 3の画像 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Motherboard: 手順 15、 3の画像 3
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  16. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 16、 3の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 16、 3の画像 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 16、 3の画像 3
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  17. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 17、 3の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 17、 3の画像 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 17、 3の画像 3
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  18. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 18、 2の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 18、 2の画像 2
    • Pull away the motherboard from the housing.
  19. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Headphone Jack: 手順 19、 1の画像 1
    • Using a Phillips #00 screwdriver, unscrew the 2 screws (3mm).
  20. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 20、 2の画像 1 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 20、 2の画像 2
    • Remove two metal support brackets.
  21. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: 手順 21、 1の画像 1
    • Lift headphone jack assembly.
終わりに
作成者
3人の作成者と共同で作成されました。
Eric Bird
メンバー登録日: 05/09/17
543 ポイント
5のガイドは作成済み
チーム
IUPUI, Team S4-G2, Harley Spring 2017 IUPUI, Team S4-G2, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S4G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 122
