メインコンテンツにスキップ
Samsung Galaxy Tab 8.9 Charging Port Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 8.9 Charging Port Replacement, Insert Opening tool: 手順 1、 1の画像 1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Charging Port Replacement, Insert second tool: 手順 2、 1の画像 1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 3、 1の画像 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 4、 1の画像 1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Charging Port Replacement, Charging Port: 手順 5、 1の画像 1
    • Using tweezers, peel away the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 6、 2の画像 1 Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 6、 2の画像 2
    • Insert a spudger under the orange tab.
    • Pry open the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 7、 1の画像 1
    • Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 8、 2の画像 1 Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 8、 2の画像 2
    • Using a Phillips #00 screwdriver, unscrew the 4 screws (3mm) that are holding the charger port and speaker support.
  9. Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 9、 1の画像 1
    • Insert opening tool to pry support from the housing.
  10. Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 10、 2の画像 2
    • Desolder the two connections to separate the speakers from the charger port.
  11. Samsung Galaxy Tab 8.9 Charging Port Replacement: 手順 11、 1の画像 1
    • Separate charging port from speaker assembly.
終わりに
作成者
3人の作成者と共同で作成されました。
Eric Bird
メンバー登録日: 05/09/17
543 ポイント
5のガイドは作成済み
チーム
IUPUI, Team S4-G2, Harley Spring 2017 IUPUI, Team S4-G2, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S4G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 667
