メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
As a laptop battery ages, it will gradually lose the ability to hold a charge and die more quickly. This guide will show you how to replace your battery and bring life back to your laptop.
パーツ
パーツは指定されていません。
  1. Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Use your hands to open the back cover.
    • Use your hands to open the back cover.
  5. Use tweezers to peel up the green tape located on top of the two flexible ribbon cables. Use tweezers to peel up the green tape located on top of the two flexible ribbon cables. Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Insert a spudger under the orange tab. Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard. Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard. Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Insert the spudger under the red, black, and white cables. Pry up and detach the battery from the motherboard. Pry up and detach the battery from the motherboard.
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Use a spudger to lift up and separate the battery from its housing. Use a spudger to lift up and separate the battery from its housing. Use a spudger to lift up and separate the battery from its housing.
    • Use a spudger to lift up and separate the battery from its housing.
終わりに
4 の人々がこのガイドを完成させました。
Dan D
メンバー登録日: 2014年09月25日
160 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 11-4, Blackwell Fall 2014 USF Tampa, Team 11-4, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S11G4
4 メンバー
10のガイドは作成済み
コメント1件
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
Paul Jackson - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 4,124
