はじめに
Use this guide to replace the front panel of your device. This will require some disassembly of your device, and removal of the front panel is required for replacing any other part on the inside of your device.
必要な工具と部品
Fully power off the device.
Disconnect and remove any cables that are connected to the device (i.e. chargers or headphones).
Place the device on a flat, stable, and clean surface.
Wedge a plastic opening tool between the front and back panel, on the bottom right corner.
Slowly push the tool down to make a small gap between the front panel and the back panel.
Holding the tool steady, run the tool along the bottom part of the device from right to left. This will make the gap between the front panel and the back panel bigger.
Leave the previously used tool wedged in the device.
Insert another plastic opening tool into the bottom of the left side, as shown.
Using a similar procedure to the last step, run the tool along the side and widen the front panel-back panel gap. This time, run the device from bottom to top.
Repeat this process for the right side of the device, starting at the bottom of the right side.
To reassemble your device, follow these instructions in reverse order. Make sure that your front panel is securely attached to the rest of your device, and that all parts of the device are aligned properly.
