Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
Several plastic tabs keep the motherboard in place, so you will have to apply some force.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
