はじめに
In this guide you will learn how to successfully pry off the rear case in order to access all the inner tablet components.
必要な工具と部品
Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
3 の人々がこのガイドを完成させました。
