メインコンテンツにスキップ
Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement, Rear Case: 手順 1、 1の画像 1
    • Before you being the replacement process, make sure the tablet is completely powered off.
    • Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
    • Right-handed users will probably be more comfortable prying in a clockwise movement, while left-handed users will feel more comfortable doing a counter clockwise movement.
    • When taking off the rear case there will be periodic clicking noises. Do not worry about those noises. They are just the rear case being disconnected.
    • Be careful not to use too much force as the plastic clips can easily be broken.
  2. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement: 手順 2、 1の画像 1
    • Place the tablet screen down on a clean surface.
    • Grasp the back panel and lift it from the device.
  3. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement, Front Facing Camera: 手順 3、 1の画像 1
    • The front facing camera's ribbon cable is located at the top edge of the motherboard, slightly left of center.
    • Slide the flat end of the blue plastic opening tool underneath the connector at the end of the ribbon cable.
  4. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement: 手順 4、 1の画像 1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the front camera’s gold rectangular connector from its socket on the motherboard.
  5. Samsung Galaxy Tab 4 8.0 Wi-Fi Front Facing Camera Replacement: 手順 5、 1の画像 1
    • Squeeze the gold rectangular piece with the tweezers to gently lift it from its pit.
終わりに
作成者
5人の作成者と共同で作成されました。
Cameron Morrow
メンバー登録日: 04/14/16
384 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 25-3, Maness Spring 2016 Cal Poly, Team 25-3, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S25G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 293
