メインコンテンツにスキップ
はじめに
After damaging your front camera, you might feel intimidated to dig into the Samsung Galaxy Tab 4 8.0. Replacing the front camera will only require, a plastic opening tool, tweezers, muscle strength, and these easy to follow instructions. The replacement will be a breeze, but be sure not use too much force when prying the device open.
  1. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: 手順 1、 3の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: 手順 1、 3の画像 2 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: 手順 1、 3の画像 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 手順 2、 2の画像 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 手順 3、 2の画像 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: 手順 4、 3の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: 手順 4、 3の画像 2 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: 手順 4、 3の画像 3
    • The front camera's ribbon cable is located just above the battery, slightly to the left.
    • Carefully insert the flat end of the blue plastic opening tool under the connector at the end of the ribbon cable.
  5. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 手順 5、 1の画像 1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the front camera’s gold rectangular connector from its socket on the motherboard.
  6. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 手順 6、 2の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: 手順 6、 2の画像 2
    • Squeeze the gold rectangular piece with the tweezers to gently lift it from its pit.
終わりに
Ofelia Cruz
メンバー登録日: 2015年09月14日
1,119 ポイント
5のガイドは作成済み
チーム
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015人のメンバー
CSUF-BRUCE-F15S1G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 449
