メインコンテンツにスキップ
はじめに
Battery life is crucial to maximizing your tablet's utility. This guide will show you the step by step replacement of the Samsung Galaxy Tab 4 8.0 battery. Although replacement is fairly easy, if your tablet's battery has more adhesive than usual, extra force will be needed.
  1. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: 手順 1、 3の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: 手順 1、 3の画像 2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: 手順 1、 3の画像 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 2、 2の画像 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 3、 2の画像 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: 手順 4、 3の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: 手順 4、 3の画像 2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: 手順 4、 3の画像 3
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
  5. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 5、 1の画像 1
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
  6. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 6、 2の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 6、 2の画像 2
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
  7. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 7、 3の画像 1 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 7、 3の画像 2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: 手順 7、 3の画像 3
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
終わりに
17 の人々がこのガイドを完成させました。
Ofelia Cruz
メンバー登録日: 2015年09月14日
1,119 ポイント
5のガイドは作成済み
チーム
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015人のメンバー
CSUF-BRUCE-F15S1G3
4 メンバー
12のガイドは作成済み
3 件のコメント
Everything in this guide looks pretty good. The only thing I would add to step one is to make sure you remove both the SIM card and the Micro SD card. Failure to do so can result in a broken SIM/SD card, slot or board they are connected to.
Cameron - 返信
Worked great! Would have been better if I had the pry tools though. I am getting them next week :}
Jason Stephens - 返信
In order to open, I did not want to purchase a pry tool so I used a think screwdriver to open abit and inserted an old credit card that made the job without danger.
Carlos Blanquer Bogacz - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 21
今までの合計 25,914
