メインコンテンツにスキップ
Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: 手順 1、 2の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: 手順 1、 2の画像 2
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 2、 3の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 2、 3の画像 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 2、 3の画像 3
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 3、 3の画像 3
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 4、 3の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 4、 3の画像 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 4、 3の画像 3
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 5、 3の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 5、 3の画像 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 5、 3の画像 3
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 6、 3の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 6、 3の画像 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 6、 3の画像 3
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 7、 3の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 7、 3の画像 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 7、 3の画像 3
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 8、 3の画像 3
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
  9. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 手順 9、 3の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 手順 9、 3の画像 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: 手順 9、 3の画像 3
    • Flip the motherboard over to view the back side.
    • Locate the rear-facing camera on the motherboard.
  10. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 10、 2の画像 2
    • Use a plastic opening tool to unlock the rear-facing camera wire from the motherboard by flipping up the retaining flap.
  11. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 11、 2の画像 1 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: 手順 11、 2の画像 2
    • Use your fingers to grip the camera and carefully pull it out and away from the motherboard
終わりに
作成者
4人の作成者と共同で作成されました。
Valentina Franco
メンバー登録日: 10/03/16
434 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-3, Forte Fall 2016 Cal Poly, Team 18-3, Forte Fall 2016人のメンバー
CPSU-FORTE-F16S18G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 706
