はじめに
If your camera is taking blurry pictures, or otherwise not working properly, it may need to be replaced. This guide will demonstrate how to replace your tablet's front-facing camera.
必要な工具と部品
Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
Flip the motherboard over to view the back side.
Locate the front-facing camera on the motherboard.
ある他の人がこのガイドを完成しました。
