ビデオの概要
Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
Work the spudger underneath the battery as shown and pry the battery away from the phone case.
The battery is attached to the case with adhesive, so a bit of force is required during removal.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
