メインコンテンツにスキップ
Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Battery: 手順 1、 2の画像 1 Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Battery: 手順 1、 2の画像 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 2、 1の画像 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 3、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 5、 1の画像 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 6、 1の画像 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Motherboard: 手順 7、 2の画像 1 Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the two 2.7mm Phillips #00 screws from the motherboard.
  8. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 8、 2の画像 1 Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 8、 2の画像 2
    • Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
  9. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 9、 2の画像 1 Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: 手順 9、 2の画像 2
    • Use a spudger to pry up the motherboard, and remove it from the device.
  10. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Front and Rear Camera: 手順 10、 2の画像 1 Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Front and Rear Camera: 手順 10、 2の画像 2
    この手順で使用する道具:
    購入する
    • Pull up on the cameras with a pair of tweezers to remove.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Blake Klein
メンバー登録日: 01/29/17
70,919 ポイント
50のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 553
