メインコンテンツにスキップ
Samsung Galaxy Tab 3 Lite Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 3 Lite Camera Replacement, Rear Case: 手順 1、 3の画像 1 Samsung Galaxy Tab 3 Lite Camera Replacement, Rear Case: 手順 1、 3の画像 2 Samsung Galaxy Tab 3 Lite Camera Replacement, Rear Case: 手順 1、 3の画像 3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 2、 3の画像 1 Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 2、 3の画像 2 Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 2、 3の画像 3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
  3. Samsung Galaxy Tab 3 Lite Camera Replacement, Motherboard: 手順 3、 3の画像 1 Samsung Galaxy Tab 3 Lite Camera Replacement, Motherboard: 手順 3、 3の画像 2 Samsung Galaxy Tab 3 Lite Camera Replacement, Motherboard: 手順 3、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use a plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the ribbon cable.
    • Use the precision tweezers to gently pull the ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 4、 2の画像 2
    • Use the plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the battery ribbon cable.
    • Use the precision tweezers to remove the ribbon cable from the ZIF connector.
  5. Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 5、 2の画像 2
  6. Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 6、 1の画像 1
    • Remove the seven 4mm Phillips J000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 7、 1の画像 1
    • Use the plastic opening tool and gently pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 8、 3の画像 3
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard off the case.
  9. Samsung Galaxy Tab 3 Lite Camera Replacement, Camera: 手順 9、 2の画像 1 Samsung Galaxy Tab 3 Lite Camera Replacement, Camera: 手順 9、 2の画像 2
    • Flip the motherboard over and locate the camera in the middle.
    • Use the plastic opening tool to gently lift up the flap holding the camera cable in place.
  10. Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab 3 Lite Camera Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using precision tweezers, gently pull the camera off the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Patricia Laird
メンバー登録日: 02/09/16
924 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 11-1, Cheng Spring 2016 USF Tampa, Team 11-1, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S11G1
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 1,122
