はじめに
If you are experiencing issues with no audio or unclear audio while using the Samsung Galaxy Kids Tab 3 7.0, use this guide to replace the aux port. The aux port allows audio transmission through an auxiliary cord, and may be causing the issue.
Before starting with the replacement guide, remove any dust or debris from the port and try several different auxiliary cords to ensure the root cause of the audio issue is the aux port.
必要な工具と部品
Wedge the plastic opening tool in the seam between the screen and the back cover.
Slide the tool around all the edges and remove the screen from the back cover.
2 の人々がこのガイドを完成させました。
