メインコンテンツにスキップ
  1. Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart. Be careful when removing the screen as negligence can cause damage.
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands. Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port. Note: the connection lifts up to remove.
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. After the battery is disconnected, use the pulling tab to safely remove the battery.
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Take the plastic remover tool and gently lift the component free from the motherboard. Take the plastic remover tool and gently lift the component free from the motherboard. Take the plastic remover tool and gently lift the component free from the motherboard.
    • Take the plastic remover tool and gently lift the component free from the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
anthony gonzalez
メンバー登録日: 2014年09月22日
304 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014人のメンバー
USFT-BROWN-F14S4G2
3 メンバー
26のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 557
