メインコンテンツにスキップ
Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement
必要な工具と部品
ビデオの概要
  1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 手順 1、 3の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 手順 1、 3の画像 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: 手順 1、 3の画像 3
    • Put the scotch tape in order not to scatter pieces of glass.
    • Remove any memory card and SIM card (if the tablet is 3G version).
  2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 手順 2、 3の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 手順 2、 3の画像 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: 手順 2、 3の画像 3
    • Using plastic tools remove the back / battery cover.
    • Be careful with the Power and Volume buttons.
  3. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 3、 1の画像 1
    • Before doing anything, disconnect the battery.
  4. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 手順 4、 3の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 手順 4、 3の画像 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: 手順 4、 3の画像 3
    • This step is only if you want to replace the micro USB port flex cable.
    • Remove the two screws and disconnect the charging port flex cable from the main board.
    • Use a plastic tool to unstick the flex cable from the middle frame.
  5. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 手順 5、 3の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 手順 5、 3の画像 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: 手順 5、 3の画像 3
    • This step is for only if you want to change the battery.
    • The battery is stuck to the middle panel.
    • Use the white sticker to remove it.
  6. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 手順 6、 3の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 手順 6、 3の画像 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: 手順 6、 3の画像 3
    • 2x loudspeackers
    • Power & Volume buttons flex cable
    • Audio jack flex cable
  7. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: 手順 7、 2の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: 手順 7、 2の画像 2
    • Front camera
    • Wi-Fi antenna
  8. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 8、 3の画像 3
    • Use a heat gun or hair dryer and warm the touch screen glass. This will make the adhesive more flexible and the separation easier.
    • Use a gloves to avoid any injurys from glass.
    • Do not rush.
  9. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 9、 3の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 9、 3の画像 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 9、 3の画像 3
    • Beware for the menu buttons flex cable.
  10. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 10、 2の画像 2
    • Always test the new spare part before final installation.
  11. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 11、 3の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 11、 3の画像 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 11、 3の画像 3
    • Transfer the black tape from the old display. It keeps the distance the display from the battery and protects it from overheat.
    • If the adhesive tape is not in good condition you must install a new one.
  12. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 12、 2の画像 1 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: 手順 12、 2の画像 2
    • Start with reassembling.
    • Did you do it successfully.
終わりに
18 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,882 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,516のガイドは作成済み
コメント 1 件
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
capinneemo - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 10
過去 30 日: 51
今までの合計 25,276
