はじめに
Use this guide to replace the battery of your Samsung Galaxy Tab 3 8.0 .
Caution must be exercised with the removal of any parts in order to avoid damage to the device.
Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
After the battery is disconnected, use the pulling tab to safely remove the battery.
31 の人々がこのガイドを完成させました。
2 件のコメント
To remove the battery without risk of damage, slide the corner of an old credit card under the battery in the middle at the end opposite the connector, then slide the card down under the battery to seperate the battery from the adhesive underneath. Repeat on the other side.
Also be REALLY careful when lifting up on the battery connector. It can tear away from the motherboard easily.
