必要な工具と部品
Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
After the battery is disconnected, use the pulling tab to safely remove the battery.
Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet.
ある他の人がこのガイドを完成しました。
