メインコンテンツにスキップ
Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: 手順 1、 3の画像 1 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: 手順 1、 3の画像 2 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: 手順 1、 3の画像 3
    • To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
    • Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
    • Continue to pry off the white backing around the device, as shown in the third picture.
  2. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement: 手順 2、 1の画像 1
    • Once the backing has been pried off all around the device, remove the white backing.
  3. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: 手順 3、 3の画像 1 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: 手順 3、 3の画像 2 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: 手順 3、 3の画像 3
    • To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
    • Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
    • Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
終わりに
22 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrea Flores
メンバー登録日: 10/09/14
1,516 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 14-30, Maness Fall 2014 Cal Poly, Team 14-30, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S14G30
4 メンバー
18のガイドは作成済み
7 件のコメント
i need the back panel
Nithyanand 333 - 返信
Awesome, I was able to use this guide to easily replace the integrated battery in my seven inch version of the Galaxy Tab 3!
segin2005 - 返信
Hello,
I cannot understand why my tablet galaxy T211 3 7.0 3G can't turn on anymore... The screen is black, i don't know is happening and all the "internet tricks" power off- sounds etc doesn't function do you have any solution?
Thank u
alizeescolas - 返信
It would be easy the said. It will only take five minutes they said. Yeah right you lying ass ##&&%. It took me 2 and a half hours to get off and it was NOT easy. Not to mention the tools I was using to get it off chipped and cracked part of the white back cover.
Queen Valencia - 返信
Never buying a Galaxy Tab again!
RoRoTX Wills - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 30
今までの合計 111,936
