メインコンテンツにスキップ
Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Rear Case: 手順 1、 2の画像 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 2、 2の画像 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Battery: 手順 3、 3の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Battery: 手順 3、 3の画像 2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Battery: 手順 3、 3の画像 3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 4、 2の画像 2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 5、 3の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 5、 3の画像 2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 5、 3の画像 3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 6、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 7、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 7、 2の画像 2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 8、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 8、 2の画像 2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Motherboard: 手順 9、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Motherboard: 手順 9、 2の画像 2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 10、 1の画像 1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 11、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 12、 3の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 12、 3の画像 2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 12、 3の画像 3
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  13. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 13、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 13、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use nylon-tipped tweezers to remove the motherboard.
  14. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Speaker & Auxiliary Port: 手順 14、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Speaker & Auxiliary Port: 手順 14、 2の画像 2
    • Using the pointed end of a nylon spudger, pry upwards between the screen chassis and the auxiliary port.
    • The speaker is permanently connected to the auxiliary port and will need to be removed from the device as a single unit.
  15. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 15、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 15、 2の画像 2
    • Use the flat end of a spudger to pry upwards between the speaker and the display chassis.
    • Remove the speaker and auxiliary port assembly.
  16. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 16、 2の画像 1 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 手順 16、 2の画像 2
    • Use the pointed end of a spudger to pry upwards between the other speaker unit and the display chassis.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Corey Brown
メンバー登録日: 06/24/16
8,688 ポイント
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 16
今までの合計 1,372
