メインコンテンツにスキップ
Samsung Galaxy Tab 3 10.1 Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: 手順 1、 2の画像 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 2、 2の画像 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 手順 3、 3の画像 1 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 手順 3、 3の画像 2 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 手順 3、 3の画像 3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 4、 2の画像 2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 5、 3の画像 1 Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 5、 3の画像 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 5、 3の画像 3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 6、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 7、 2の画像 1 Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 7、 2の画像 2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 8、 2の画像 1 Samsung Galaxy Tab 3 10.1 Battery Replacement: 手順 8、 2の画像 2
    • Lift with a nylon spudger to remove the battery.
終わりに
75 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Corey Brown
メンバー登録日: 06/24/16
8,682 ポイント
11のガイドは作成済み
7 件のコメント
Great, Thanks for the help. It was very useful.
nyhorseracing - 返信
why are there white lines all over the screen after a new battery was installed
Rosita Fowler - 返信
brilliant ! worked extremely well !
Carmelo Aquilina - 返信
Thank you very much for the information. I have one question, though. The new battery works, but it takes a VERY long time to charge. More than a day, in fact. Any idea what could be causing that? Is it possible that one of the connections is not tight enough? If so, which connection might that be?
Thank you.
Paul Ross - 返信
Very easy instructions. Thank you. My only snag was that the ten screws holding the battery were extremely reluctant to undo. wrecked the IFxit screw driver. Fortunately, I had another one. My tip for anyone doing this little job, is to use quit a lot of downward pressure on the screws. Turn them 1/4 turn anticlockwise and back again. Do this several times until they turn freely. You will then have an easy job. I will replace those screws with a tiny blob of 'Never Seize'.
Keith Aldworth - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 45
過去 30 日: 271
今までの合計 42,971
