はじめに
Use this guide to replace the battery in your Samsung Galaxy Tab 3 10.1 tablet.
パーツ
パーツは指定されていません。
Insert an opening pick between the rear case and the plastic rim.
Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
Continue to slide the pick around the edge of the rear case until all clips are released.
Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
66 の人々がこのガイドを完成させました。
3 件のコメント
Great, Thanks for the help. It was very useful.
why are there white lines all over the screen after a new battery was installed
brilliant ! worked extremely well !
