メインコンテンツにスキップ
Samsung Galaxy Tab 3 10.1 Battery Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Open Device: 手順 1、 1の画像 1
    • Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
    • Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
    • During reassembly, be careful not to insert bottom, left, nor right edges first—doing so can damage the power button, and prevent the front panel from sitting totally flush.
    • If screen is cracked like shown imagine, Place tape on screen to prevent injury.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement, Ribbon Cables: 手順 2、 1の画像 1
    • Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery Screws: 手順 3、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
    • Make sure to keep screws in a secure location for reassembly.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement, Removal: 手順 4、 1の画像 1
    • Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
終わりに
45 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Fabio
メンバー登録日: 10/16/14
1,506 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-2, Duarte Fall 2014 UMass Dartmouth, Team 2-2, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S2G2
4 メンバー
6のガイドは作成済み
4 件のコメント
is there a diference between the lte, 3g and wifi versions of the samsung tablet
Josh Robinson - 返信
thanks for the information. i will use it wisely.
Adelle Bradley - 返信
Battery changed, works fine !
Thank you for the tuto :-)
Sharky Billy - 返信
Great guide thank you.
My cover is not flush, even though I carefully attached the top first then downwards - I'm just clumsy I guess.
George Cooke - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 54,391
