メインコンテンツにスキップ
Samsung Galaxy Tab 2 7.0 Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 2 7.0 Motherboard Replacement, Preparing Your Device: 手順 1、 2の画像 1 Samsung Galaxy Tab 2 7.0 Motherboard Replacement, Preparing Your Device: 手順 1、 2の画像 2
    • Power the device down completely
    • Remove the SD card from the SD card slot.
  2. Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 2、 2の画像 2
    • Use the prying tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Be sure to unclip all of the clips on the back panel or it will be difficult for you to pull it off and may damage the tablet.
  3. Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 3、 2の画像 1 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the battery Flex Cable from its socket by placing the pry tool under the wires and gently prying it out.
    • When you are placing in the new battery, it helps to connect the socket first or else it becomes difficult to properly align once the battery is in place.
  4. Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 4、 3の画像 1 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 4、 3の画像 2 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 4、 3の画像 3
    • Using the Phillips precision screw driver remove the six 4 mm screws holding the battery in place.
    • Once the battery is loose, remove as shown.
  5. Samsung Galaxy Tab 2 7.0 Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Using the Phillips #00 precisions screwdriver, remove the 12 4mm screws holding in the motherboard.
  6. Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 6、 3の画像 1 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 6、 3の画像 2 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 6、 3の画像 3
    • Release all flex cable connections at the bottom section of the motherboard.
    • Using the plastic pry tool release connections for both loudspeakers.
    • Once disconnected gently remove the loudspeakers from the device.
  7. Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 7、 3の画像 1 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 7、 3の画像 2 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 7、 3の画像 3
    • Release all flex cables on the right side of the device motherboard as shown.
    • Using the plastic pry tool, release the touch screen flex cable from its socket.
    • With the same tool release the LCD screen flex cable form its socket.
  8. Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 8、 2の画像 1 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 8、 2の画像 2
    • Release all flex cables on the upper portion of the motherboard.
    • Using the plastic pry tool release the sensor flex cable from its socket.
    • With the same tool release the camera flex cable from its socket.
    • Release the front camera flex cable from its socket.
    • Release the side button's flex cable from its socket.
    • There is one more Flex cable to remove, it's to the right of the front camera connector (see previous picture with connector highlighted in yellow box). It connects the top microphone and headphone jack.
  9. Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab 2 7.0 Motherboard Replacement: 手順 10、 2の画像 2
    • Gently remove the motherboard from the device.
    • Be sure no flex cables get caught on the motherboard while you are removing it or the flex cables may become damaged.
    • It is easier to begin lifting the motherboard from the top rather than the bottom.
終わりに
15 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Paul
メンバー登録日: 03/05/15
2,183 ポイント
4のガイドは作成済み
チーム
Sam Houston State, Team 11-5, Blackburne Winter 2015 Sam Houston State, Team 11-5, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S11G5
3 メンバー
4のガイドは作成済み
6 件のコメント
I need new Samsung Tab 2 16 Gb Motherboard. Kindly suggest me somthing.
vishal - 返信
Thanks for sharing this information.
How, can I stop my tablet from Boot Looping?
Kia - 返信
Need Samsung Galaxy Tab 2 GT-P3100 16 Gb Variant motherboard
Harsh - 返信
hi, i need some help for my samsung galaxy tab 2 7.0 running on stock android 4.1.2, unrooted. It boots into the home screen, and I can access safe mode too, but if you use it for long, it restarts and again and again. when I tried to wipe the data on it through the recovery mode, it says data wipe complete, but when it reboots, it has the same files as if nothing happened. I also tried flashing a stock rom to it through the recovery mode and odin, but it hangs halfway through and reboots again with the same files.
Logan Wolverine - 返信
Can I replace WiFi motherboard with a SIM Motherboard?
Mobility Tester - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 13,427
