メインコンテンツにスキップ
Samsung Galaxy Tab 2 7.0 Disassembly
必要な工具と部品
  1. Samsung Galaxy Tab 2 7.0 Disassembly, Tools Required: 手順 1、 2の画像 1 Samsung Galaxy Tab 2 7.0 Disassembly, Tools Required: 手順 1、 2の画像 2
    • 00 Phillips Driver Bit
    • Plastic and Metal Prying Tools
    • Plastic Spudger
    • Tweezers
  2. Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Back Cover: 手順 2、 3の画像 1 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Back Cover: 手順 2、 3の画像 2 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Back Cover: 手順 2、 3の画像 3
    • Get a pry tool and go along the edge of the cover
    • Twist the pry tool to un-clip the clips
    • This can take some time and can be difficult.
  3. Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Battery: 手順 3、 3の画像 1 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Battery: 手順 3、 3の画像 2 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Battery: 手順 3、 3の画像 3
    • Get a plastic spudger and push upwards on the underside of the connector
    • Then unscrew the battery from the body.
    • Then you can remove the battery by simply lifting it out of the case.
    • DO NOT use metal pry tools or try to pry the battery out with them if it is stuck. Use gentle pressure with a plastic pry tool to pry the battery out.
    • You will want to remove the battery first to remove all power from the device so you don't short or damage anything inside.
  4. Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Speakers: 手順 4、 3の画像 1 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Speakers: 手順 4、 3の画像 2 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Speakers: 手順 4、 3の画像 3
    • Un-screw the two screws on each of the speakers.
    • Use the plastic spudger to un-clip the connectors. These work like Lego bricks.
    • You can then remove the speakers.
  5. Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Motherboard Part 1: 手順 5、 3の画像 1 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Motherboard Part 1: 手順 5、 3の画像 2 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Motherboard Part 1: 手順 5、 3の画像 3
    • Un-clip all of the ribbon connectors from the board.
    • Be careful to not tare any of the ribbon cables.
  6. Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Motherboard Part 2: 手順 6、 3の画像 1 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Motherboard Part 2: 手順 6、 3の画像 2 Samsung Galaxy Tab 2 7.0 Disassembly, Removing The Motherboard Part 2: 手順 6、 3の画像 3
    • Un-screw all of the screws from the board.
    • You can then remove the metal shield from the board.
    • After, you can remove the motherboard by pulling up from the top and slide it out of the power connector port.
    • Near the top there is some adhesive which can be a bit hard but giving the board a bit or leverage.
  7. Samsung Galaxy Tab 2 7.0 Disassembly, Removing Other Components: 手順 7、 3の画像 1 Samsung Galaxy Tab 2 7.0 Disassembly, Removing Other Components: 手順 7、 3の画像 2 Samsung Galaxy Tab 2 7.0 Disassembly, Removing Other Components: 手順 7、 3の画像 3
    • You can then remove the components such as the cameras and the mic.
    • To remove the headphone jack you un-screw the metal bracket.
    • The MIC and the AUX port are held in by adhesive but giving it a bit of a push should set them both free.
  8. Samsung Galaxy Tab 2 7.0 Disassembly, Completed: 手順 8、 1の画像 1
    • You will be left with the display as one piece. If you need a screen replacement you can replace the whole screen.
終わりに
11 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Hadena
メンバー登録日: 07/13/18
915 ポイント
2のガイドは作成済み
コメント 1 件
Which is the screen connector
toddjohnson4208 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 36
今までの合計 5,372
