メインコンテンツにスキップ
Samsung Galaxy Tab 2 10.1 Motherboard Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Back Cover: 手順 1、 2の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Back Cover: 手順 1、 2の画像 2
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
    Note that the headphone port protrudes into the back cover framing. Hence the rest of the back needs to be unclipped and taken off first.
    Levi Howard - 返信
    I had problems getting it to separate at first. Pushing down with my thumb on the very edge of the case from the front while pushing up with my fingers from the back flexed it enough to get a very small jeweler’s screwdriver in the gap. From there I worked it until I could get the little bread wrapper plastics clips in the space. When it needed something stronger a 1 or 2 inch plastic putty knife from Walmart did the trick.
    William H Bowers - 返信
    I replaced the battery and nothing no screen nothing. the batt was 3.7 V though.
    The old one had 0V. I might have messed up the ribbon cables?
    I put back the cover on it.
    Held on the power button for 10 seconds, nothing. Held the power button and the volume up button for 10 seconds… also nothing..
    I am leaving it charge for a while now. Even though if your battery is like full (3.7V measured) it should come on… but nothing..
    Lets wait and see. Or this will be garbage…
    xbox40489 - 返信
  2. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 2、 2の画像 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Battery Disconnect: 手順 3、 1の画像 1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 4、 3の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 4、 3の画像 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 4、 3の画像 3
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Front Camera: 手順 5、 2の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Front Camera: 手順 5、 2の画像 2
    • Gently lift the camera from its socket with the flat end of the heavy-duty spudger.
  6. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 6、 1の画像 1
    • Gently lift the gold cable connector with the flat end of the heavy-duty spudger to disconnect it from the device.
  7. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Charger Port: 手順 7、 2の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Charger Port: 手順 7、 2の画像 2
    • The charging port cable is the black cable connected to the charger port. Using your fingers, peel the green tape off of the charging port cable connector.
  8. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 8、 2の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 8、 2の画像 2
    • Using the flat end of heavy-duty spudger, carefully lift the black tab that holds the charger port cable in place.
    • Slide the cable out.
    • There is a small strip of adhesive holding the charger port cable to the battery. You may need to slide the heavy-duty spudger between the cable and the battery to slide the cable out.
  9. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 9、 3の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 9、 3の画像 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 9、 3の画像 3
    • Use the Phillips 000 screwdriver to unscrew the two 3mm screws holding the charger port in place.
  10. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 10、 1の画像 1
    • Use the flat end of the heavy-duty spudger to lift the white microphone piece until it is removed from its socket.
  11. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 11、 3の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 11、 3の画像 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 11、 3の画像 3
    • Be sure to insert the spudger underneath the charger port and not inside the charger port to avoid damaging the component
    • Slide the flat end of the heavy-duty spudger under the charger port.
    • Make sure the spudger is all the way to the back of the cavity and slide horizontally across the bottom to break the adhesive.
    Where can I buy that part from
    Ronald Thomad - 返信
    I need the charging port
    Ronald Thomad - 返信
  12. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 12、 1の画像 1
    • Lift the charger port with the flat end of the heavy-duty spudger and remove it from the device.
  13. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Battery: 手順 13、 3の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Battery: 手順 13、 3の画像 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Battery: 手順 13、 3の画像 3
    • Using your fingers, remove the green tape holding the three ribbon cables down.
    • Using the flat end of the heavy-duty spudger, carefully lift the black tab that holds the leftmost, black ribbon cable in place. Repeat this step for the gold ribbon cable and the black ribbon cable.
    • Using your fingers, gently slide each of the three cables straight out of the connectors.
  14. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 14、 1の画像 1
    • Using a Phillips #000 screwdriver, remove the ten 3mm screws that hold the battery down.
  15. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 15、 2の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 15、 2の画像 2
    • Lift the battery with your hands and remove it from the device.
    It would be helpful to advise that the headphone port protrudes and hence the back needs to be taken off with that in mind (ie, the rest of the back first)
    Levi Howard - 返信
    trés bonnes explications…. Changement de batterie réussi MAIS impossible de remettre les nappes en place…Craignant ce problème je n’avais pas débranché celle du milieu; la batterie glisse dessous….J’aurais du le faire pour les autres! La tablette va à la déchetterie!
    5puy32@orange.fr - 返信
    xbox40489 - 返信
    I'm in the same situation, coming from a fully depleted/broken battery.
    Were you able to start the tablet?
    Thanks!
    Carlos Iván Conde Martín -
  16. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Motherboard: 手順 16、 2の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Motherboard: 手順 16、 2の画像 2
    • Using the flat end of the heavy-duty spudger, lift up the black ribbon lock directly left of the headphone jack from the black side.
    • After lifting up the lock, insert the heavy-duty spudger underneath the gold ribbon and slide to disconnect the gold ribbon.
  17. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 17、 1の画像 1
    • The rear camera may pop out.
    • Using the flat end of the heavy-duty spudger, gently lift up the ribbon lock directly above the one in the previous step from the brown side.
    • After lifting up the lock, remove the gold ribbon with the heavy-duty spudger as you did in the previous step.
  18. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 18、 1の画像 1
    • Use the flat end of the heavy-duty spudger to pop off and disconnect all the marked connectors attached to the motherboard.
  19. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 19、 2の画像 1 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: 手順 19、 2の画像 2
    • After disconnecting all of the connectors, push up on the motherboard with your thumbs to dislodge it from the tabs fastening the bottom of the motherboard. Then lift up the motherboard to carefully remove it from the device.
    • You may need to repeat this step a few times. The motherboard can be difficult to remove.
終わりに
19 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Gabriel Rodarte
メンバー登録日: 02/08/15
435 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-26, Amido Winter 2015 Cal Poly, Team 6-26, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S6G26
5 メンバー
14のガイドは作成済み
5 件のコメント
Is there any sodering required to install it?
Ross Hanson - 返信
All connections with other components come via cable connectors at different points on the board, but all components of the motherboard come complete already on the board, many with EMI shields.
Here is the link to the part product page which can give you pictures of the part itself which looks like the final picture of Step 19
Robert Myers - 返信
The Instructions and illustrations were very helpful to follow and replace Motherboard for Samsung galaxy tablet S2 10.1,
I will need to purchase the part at our local elecrtonics shop and hopefully might find one and do the replacement following your instruction guide.
If not able to find at our local shops then I would place order with you and purchase part from you.
Thank you very much for kind assistance,
Regards,
Charlie Jay Klobill,
Wabag, Enga Province, PNG - 29/03/2020
Charlie Jay Klobill - 返信
If I purchase a new motherboard and replace mine,will I have to load another operating system into it? If I do,is this an easy thing to do and where do I get it from? Thanks Steve Canode
scanode - 返信
i need a motherboad
shivam Kumar - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 25
過去 30 日: 79
今までの合計 16,646
