メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Tab 2 10.1 Battery Disconnect
必要条件のみ
これは前提条件のみのガイドです!このガイドは別の手順の一部であり、単独で使用されません。
必要な工具と部品
  1. Samsung Galaxy Tab 2 10.1 Battery Disconnect, Back Cover: 手順 1、 2の画像 1 Samsung Galaxy Tab 2 10.1 Battery Disconnect, Back Cover: 手順 1、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Spudger
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Galaxy Tab 2 10.1 Battery Disconnect: 手順 2、 2の画像 1 Samsung Galaxy Tab 2 10.1 Battery Disconnect: 手順 2、 2の画像 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Galaxy Tab 2 10.1 Battery Disconnect, Battery Disconnect: 手順 3、 1の画像 1
    • Using your fingers, remove the green tape covering the battery connector.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Galaxy Tab 2 10.1 Battery Disconnect: 手順 4、 3の画像 1 Samsung Galaxy Tab 2 10.1 Battery Disconnect: 手順 4、 3の画像 2 Samsung Galaxy Tab 2 10.1 Battery Disconnect: 手順 4、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Spudger
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Daniel Rostom
メンバー登録日: 02/02/15
834 ポイント
2のガイドは作成済み
2件のガイドコメント
Disconnected the battery, checked the contacts, reconnected it. As soon as I reconnected the battery I could smell and feel heat from the two silver areas on the MB (guessing RAM/Processors are under there). Still doesn't turn on. Any ideas?
Glenn G - 返信 共有
Those pictures are of a Galaxy Note, T-8013, not a Tab 2.
Brian Clancy - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 32
今までの合計 3,418
