メインコンテンツにスキップ
はじめに
This guide will teach you how to remove the back cover from your tablet, a prerequisite step to the other guides.
パーツ
パーツは指定されていません。
  1. The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead. Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Gently lift the screen up with your finger. If the screen will not separate from the back cover, try repeating step 1.
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
終わりに
Gabriel Rodarte
メンバー登録日: 2015年02月08日
423 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-26, Amido Winter 2015 Cal Poly, Team 6-26, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S6G26
5 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 198
