メインコンテンツにスキップ
Samsung Galaxy Tab 10.1 Rear Panel Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 10.1 Rear Panel Replacement, Rear Panel: 手順 1、 2の画像 1 Samsung Galaxy Tab 10.1 Rear Panel Replacement, Rear Panel: 手順 1、 2の画像 2
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Rear Panel Replacement: 手順 2、 3の画像 1 Samsung Galaxy Tab 10.1 Rear Panel Replacement: 手順 2、 3の画像 2 Samsung Galaxy Tab 10.1 Rear Panel Replacement: 手順 2、 3の画像 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Rear Panel Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab 10.1 Rear Panel Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab 10.1 Rear Panel Replacement: 手順 3、 3の画像 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
終わりに
13 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Davie Sy
メンバー登録日: 09/30/13
1,421 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 13-5, Forte Fall 2013 Cal Poly, Team 13-5, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S13G5
5 メンバー
17のガイドは作成済み
4 件のコメント
Very interesting, but my note 10.1 does not have these two screws adjacent to the charge point as you describe. So mine is a bit different. There are no screws anywhere on the tablet. So how do I take the back off mine ??
James Tobin - 返信
It currently won’t start and I have read about a fix that requires the back to be removed.
James Tobin - 返信
What - How - Ware ? Yes I looked online for the parts, no I was not successful in finding the parts online. Can you tell me ware you found the parts for this project?
Brian Elling - 返信
i need the panel
Ay Bami - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 28
今までの合計 38,973
