はじめに
In this guide, you will learn how to remove and replace your rear facing camera on your Samsung Galaxy Tab 10.1. A broken rear camera makes for difficult taking pictures of beautiful landscapes or family gatherings. There are a couple of prerequisites to get out of the way first!
Place the bottom of the tablet towards you.
Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
Carefully pull the three ribbon cables from their sockets on the motherboard.
Use the spudger to pry up on the white connection of the rear camera wire.
ある他の人がこのガイドを完成しました。
