メインコンテンツにスキップ
Samsung Galaxy Tab 10.1 Front Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 10.1 Front Facing Camera Replacement, Rear Panel: 手順 1、 2の画像 1 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement, Rear Panel: 手順 1、 2の画像 2
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 2、 3の画像 1 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 2、 3の画像 2 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 2、 3の画像 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 3、 3の画像 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  4. Samsung Galaxy Tab 10.1 Front Facing Camera Replacement, Battery: 手順 4、 3の画像 1 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement, Battery: 手順 4、 3の画像 2 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement, Battery: 手順 4、 3の画像 3
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
  5. Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 5、 2の画像 2
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  6. Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 6、 3の画像 1 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 6、 3の画像 2 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 6、 3の画像 3
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
  7. Samsung Galaxy Tab 10.1 Front Facing Camera Replacement, Front Facing Camera: 手順 7、 2の画像 1 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement, Front Facing Camera: 手順 7、 2の画像 2
    • Use the spudger to pry up on orange connection. This is the connection to the front facing camera.
  8. Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab 10.1 Front Facing Camera Replacement: 手順 8、 3の画像 3
    • Grab the orange connection with your fingers and lift it up from its slot.
    • We have removed the motherboard in these pictures to make it easier to see, but it is not necessary to complete this step.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Davie Sy
メンバー登録日: 09/30/13
1,421 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 13-5, Forte Fall 2013 Cal Poly, Team 13-5, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S13G5
5 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 10
今までの合計 3,191
