メインコンテンツにスキップ
Samsung Galaxy Tab 10.1 Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 10.1 Battery Replacement, Rear Panel: 手順 1、 2の画像 1 Samsung Galaxy Tab 10.1 Battery Replacement, Rear Panel: 手順 1、 2の画像 2
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
    Access denied! The screws near the port are covered by buttons. I wedged a pointed screw and hammered "gently" until they popped out. Problem solved!
    Daniella - 返信
    My model doesn't have any screws!
    Barry - 返信
    What can I do if my model DOESN'T HAVE ANY SCREWS? It has a loose LCD cable so SOME of my colours are all mixed up. This is really frustrating so please help
    Janine Coetzee - 返信
    I have SG Tab Pro 10.1
    There are no screws..... now what?
    iloveto travel - 返信
    Great instructions! Easy to follow.
    skritzberger - 返信
    My model has no screws.
    Faith Odutola - 返信
    My model has no screws and doesn't look like the one pictured here. It's a model SM-T580.
    Elsa Kramer - 返信
    Be careful removing the two screw plugs by the 30 pin connector. They are easy to scratch. I couldn’t get the plugs out with my tool kit and finally removed them with the point of an exacto knife.
    Behind the two plugs are sticky pads that will need to be handled carefully and saved for reassembly.
    If you order a tool kit online, be sure it has a Y1 tri-wing screwdriver. The one in my kit was not Y1 and would not remove the screws.
    I had to order a new screwdriver.
    George Tomlinson - 返信
    I don't see any screws I have a galaxy tab 4
    Tammylynn Gmarter - 返信
    if your model doesn’t have these screws, it’s probably ok to just skip this step. at least that’s what i did on model gt-p7500, and that repair was successful (battery replacement). Janine, a friend asked me to fix his Tab where that had happened when he tried to replace the battery himself… i just took out the 3 big cables over the battery, and re-inserted them, and that fixed the problem. you should try that if you haven’t already..
    divinity76 - 返信
    Mine doesn't have screws so what do I do now?
    katrinawisner - 返信
    charging samsung battery dabka ilaaliyo
    Maxamed Xuseen - 返信
  2. Samsung Galaxy Tab 10.1 Battery Replacement: 手順 2、 3の画像 1 Samsung Galaxy Tab 10.1 Battery Replacement: 手順 2、 3の画像 2 Samsung Galaxy Tab 10.1 Battery Replacement: 手順 2、 3の画像 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Battery Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab 10.1 Battery Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab 10.1 Battery Replacement: 手順 3、 3の画像 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  4. Samsung Galaxy Tab 10.1 Battery Replacement, Battery: 手順 4、 3の画像 1 Samsung Galaxy Tab 10.1 Battery Replacement, Battery: 手順 4、 3の画像 2 Samsung Galaxy Tab 10.1 Battery Replacement, Battery: 手順 4、 3の画像 3
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
    Looking at the ZIF connectors in step 4....mine isn't charging. I suspect the problem lies in the jack for the USB/power cable. Would I be correct in thinking it's a matter of following to this point, then replacing the internal cable?
    gzapiec - 返信
    I took the cable all the way off and can't get on what to
    I have sound but no pictures/screen what did I do wrong what should I check?
    Rodney perini - 返信
    If you don't have a picture on the screen, it could be caused by an issue with the electrical connectivity on one or other of the power/ data cables. Carefully unplug, clean and re-seat each of the cables, ensure if you use cotton buds, that you use a high powered magnifying glass to check for any flecks left behind….
    Re-seat the. Cables and try again.
    I hope this works for you Rod…
    By the way, to confirm a backlight issue, get a high power torch, or your mobile phone torch will do. Now shine this closely at an angle to the screen. You might see a faint non-illuminated screen!
    Phillip Gamble - 返信
  5. Samsung Galaxy Tab 10.1 Battery Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab 10.1 Battery Replacement: 手順 5、 2の画像 2
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  6. Samsung Galaxy Tab 10.1 Battery Replacement: 手順 6、 3の画像 1 Samsung Galaxy Tab 10.1 Battery Replacement: 手順 6、 3の画像 2 Samsung Galaxy Tab 10.1 Battery Replacement: 手順 6、 3の画像 3
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
    Very simple, clever and effective presentation of opening rear cover.Thanks very much for simplicity. The way presented is user friendly.
    Video presentation is mostly in dark ambient, it is useless. Once moore thank you very much.
    Ljubo Baricevic - 返信
    The battery connector lifts up, not back. A plastic tool lifting under the five wires from the battery right at the base of the connector helps.
    Peter Mui - 返信
    then what where do you buy a battery
    Janie montemayor - 返信
    ok after its all apart where do i buy the battery
    @janiemontemayor Sorry about that—the link for the replacement battery was out of date. It's fixed now! Try the link at the top of this guide.
    Jeff Suovanen -
    Welches Tablet hast du denn da? Mein 10.1 hat keine Schrauben an der Ladebuchse
    Anja Mickenbecker - 返信
終わりに
61 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jess McCafferty
メンバー登録日: 09/30/13
1,704 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 13-5, Forte Fall 2013 Cal Poly, Team 13-5, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S13G5
5 メンバー
17のガイドは作成済み
20 件のコメント
Those 3 plastic bands with connectors at the end are a really poor design and a drag to put back on correctly : there's a little white line drawn on each one that needs to be aligned with a line drawn on the socket itself. This means you really have to push them back in (with a little platic tool for example). If not you can have a non functioning screen or no touch detection.
zen - 返信
What if your stupid aunt is trying to open it and you can open it but she said that you broke it? What can I do about it. Ppl. HM
Isabella - 返信
What would be the correct battery that is suitable for the Tab proT520? I can't find any reference to this particular models battery..
Tomjonkins - 返信
Nice tutorials, thank you! I want to ask you about exactly battery. Where is it better to order it/ I mean, if i order it online? I live in Europe and know some stores of hardware, such as hardware.nu and so on but also i know such stores as Amazon and eBay also Aliexpress..Tell me where is quaity is the best?
Scott Waschlerner - 返信
I have a tab 10.1 but there are no screws on the outside.
Ultra Fox - 返信
Is it possible to swap the original battery for one with more capacity? I love my Tab 4 10.1, but since I'm using it with a bluetooth keyboard the battery is draining too fast...
Rob - 返信
I was told that the cost of a replacement battery would equal the cost of a new tablet. Apparently not. Frustrating is a very accurate description as to my feelings towrd this issue. Fully charged to dead in under an hour.Overrheatted chargers, the unit just stopping. Many things.. I'll be in touch after the New Year.
billjkays1954 - 返信
I was told the same thing at Best Buy. Would be as expensive as a new one. Guess they are not well versed on actual practical matters of the Galaxy tab 10. Orrrrr. They just want to sell you a new one!
gregandgeribo - 返信
I have a Tab A 10.1 but my back panel doesn't look like the one in the tutorial. Are there any alternative tutorials/panels? Mine only has one black ribbon and a skinny white one next to it. ???
yvettemichele - 返信
Same man. My problem is the tablet is 100000% working but the screen is PLAIN black. Like all black. I was being a dumb arse by getting mad at a game and smashed my head at the tab. After that it paused for a split sec and then the screen just when black. I am too young to order any plastic prying tools online. I even managed to open youtube and play a random video. I also get notifs from my subs. The edges on the tab are different from most tabs. Can anyone tell me some house hold items i can use to pry open the edges? Thank you.
random guy -
I also have a 10.1 and there are not screws , just smooth round silver end caps of some sort.
Sue McFeron - 返信
You have to remove the caps, then remove the stickers underneath the caps. I used an exacto knife to remove them. Be careful though.
Christopher Rodriguez - 返信
guitar picks work great
Lisa Lingo - 返信
très bien fait un peu rapide sur les actions délicates '“ enlever les nappes “ et pas d info sur la recharge apres changement
cordialement
pascal
Pascal Guiguet - 返信
there are no caps on mine. I have looked and felt all the way around the tablet. Now what?
omenmoon - 返信
replaced battery as directed. Plugged in to charger but nothing is happening. Should It start chargeing right away??
rita fairbairn - 返信
I have a question. The flaps on the ZIF connector from the cable from the sockets on the motherboard has fallen off can it be replaceable?
Jennifer Durham - 返信
Charging system
wl12844886 - 返信
The tablet does not charge
wl12844886 - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 47
過去 30 日: 170
今までの合計 359,886
