はじめに
In this guide, you will learn how to replace the battery on your Samsung Galaxy Tab 10.1. Having a bad or broken battery can be frustrating. There are a couple prerequisites we need to get out of the way first!
必要な工具と部品
Place the bottom of the tablet towards you.
Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
Carefully pull the three ribbon cables from their sockets on the motherboard.
I took the cable all the way off and can't get on what to
I have sound but no pictures/screen what did I do wrong what should I check?
If you don't have a picture on the screen, it could be caused by an issue with the electrical connectivity on one or other of the power/ data cables. Carefully unplug, clean and re-seat each of the cables, ensure if you use cotton buds, that you use a high powered magnifying glass to check for any flecks left behind….
Re-seat the. Cables and try again.
I hope this works for you Rod…
By the way, to confirm a backlight issue, get a high power torch, or your mobile phone torch will do. Now shine this closely at an angle to the screen. You might see a faint non-illuminated screen!
Lift the edge of the battery up with your finger or a spudger.
Detach the battery by holding the motherboard down while gently lifting the battery up.
Very simple, clever and effective presentation of opening rear cover.Thanks very much for simplicity. The way presented is user friendly.
Video presentation is mostly in dark ambient, it is useless. Once moore thank you very much.
then what where do you buy a battery
ok after its all apart where do i buy the battery
@janiemontemayor Sorry about that—the link for the replacement battery was out of date. It's fixed now! Try the link at the top of this guide.
Welches Tablet hast du denn da? Mein 10.1 hat keine Schrauben an der Ladebuchse
61 の人々がこのガイドを完成させました。
20 件のコメント
Those 3 plastic bands with connectors at the end are a really poor design and a drag to put back on correctly : there's a little white line drawn on each one that needs to be aligned with a line drawn on the socket itself. This means you really have to push them back in (with a little platic tool for example). If not you can have a non functioning screen or no touch detection.
What would be the correct battery that is suitable for the Tab proT520? I can't find any reference to this particular models battery..
Tomjonkins - 返信
good jobs man
Nice tutorials, thank you! I want to ask you about exactly battery. Where is it better to order it/ I mean, if i order it online? I live in Europe and know some stores of hardware, such as hardware.nu and so on but also i know such stores as Amazon and eBay also Aliexpress..Tell me where is quaity is the best?
I was told that the cost of a replacement battery would equal the cost of a new tablet. Apparently not. Frustrating is a very accurate description as to my feelings towrd this issue. Fully charged to dead in under an hour.Overrheatted chargers, the unit just stopping. Many things.. I'll be in touch after the New Year.
I was told the same thing at Best Buy. Would be as expensive as a new one. Guess they are not well versed on actual practical matters of the Galaxy tab 10. Orrrrr. They just want to sell you a new one!
I have a Tab A 10.1 but my back panel doesn't look like the one in the tutorial. Are there any alternative tutorials/panels? Mine only has one black ribbon and a skinny white one next to it. ???
Same man. My problem is the tablet is 100000% working but the screen is PLAIN black. Like all black. I was being a dumb arse by getting mad at a game and smashed my head at the tab. After that it paused for a split sec and then the screen just when black. I am too young to order any plastic prying tools online. I even managed to open youtube and play a random video. I also get notifs from my subs. The edges on the tab are different from most tabs. Can anyone tell me some house hold items i can use to pry open the edges? Thank you.
I also have a 10.1 and there are not screws , just smooth round silver end caps of some sort.
You have to remove the caps, then remove the stickers underneath the caps. I used an exacto knife to remove them. Be careful though.
guitar picks work great
Lisa Lingo - 返信
très bien fait un peu rapide sur les actions délicates '“ enlever les nappes “ et pas d info sur la recharge apres changement
cordialement
pascal
replaced battery as directed. Plugged in to charger but nothing is happening. Should It start chargeing right away??
I have a question. The flaps on the ZIF connector from the cable from the sockets on the motherboard has fallen off can it be replaceable?
Charging system
wl12844886 - 返信
The tablet does not charge
wl12844886 - 返信
Access denied! The screws near the port are covered by buttons. I wedged a pointed screw and hammered "gently" until they popped out. Problem solved!
Daniella - 返信
My model doesn't have any screws!
Barry - 返信
What can I do if my model DOESN'T HAVE ANY SCREWS? It has a loose LCD cable so SOME of my colours are all mixed up. This is really frustrating so please help
Janine Coetzee - 返信
I have SG Tab Pro 10.1
There are no screws..... now what?
iloveto travel - 返信
Great instructions! Easy to follow.
skritzberger - 返信
My model has no screws.
Faith Odutola - 返信
My model has no screws and doesn't look like the one pictured here. It's a model SM-T580.
Elsa Kramer - 返信
Be careful removing the two screw plugs by the 30 pin connector. They are easy to scratch. I couldn’t get the plugs out with my tool kit and finally removed them with the point of an exacto knife.
Behind the two plugs are sticky pads that will need to be handled carefully and saved for reassembly.
If you order a tool kit online, be sure it has a Y1 tri-wing screwdriver. The one in my kit was not Y1 and would not remove the screws.
I had to order a new screwdriver.
George Tomlinson - 返信
I don't see any screws I have a galaxy tab 4
Tammylynn Gmarter - 返信
if your model doesn’t have these screws, it’s probably ok to just skip this step. at least that’s what i did on model gt-p7500, and that repair was successful (battery replacement). Janine, a friend asked me to fix his Tab where that had happened when he tried to replace the battery himself… i just took out the 3 big cables over the battery, and re-inserted them, and that fixed the problem. you should try that if you haven’t already..
divinity76 - 返信
Mine doesn't have screws so what do I do now?
katrinawisner - 返信
charging samsung battery dabka ilaaliyo
Maxamed Xuseen - 返信
